Hello can anyone help please I have a problem with my fuel pump on my Golf GTi its a 1991 J reg 1.8, 8 valve PB engine it appears to be standard apart from a k&n cone air filter and four branch manifold with jetex exhaust not that I can see that would make a difference but. When you turn the ignition on the fuel pump primes as usual but it doesn't stop priming just keeps running, otherwise it starts and runs fine, is there a pressure switch somewhere on the fuel system to turn this off when it gets to pressure ? I presume there is if so can anyone tell me where it is located thanks in advance.
Thanks rubjonny I will look into it, Its a project car so will probably look into it after inters as Ive got to clean my other mk2 ready for Saturday.
Sorry to bring this back up but did you manage to sort this fault out as I am having same issue not being able to get fuel pump to stop priming.
