I have owned this Golf since September 2000. I bought at a garage called Stirling Motors in Croydon. Car started life as a 1.8 8V GTi with around 50, 000 miles on the clock when I bought it. These are the mods that have been done over the years; Mods: • Bottom end bored out to 1900cc with 0 miles on the clock, new shells, piston rings, core plugs, big end bolts and reground crank Before I BLEW UP ENGINE. • Stage 2 tuned PB cylinder head, polished and ported cylinder head with new bucket tappets, head gasket and head bolts. • New cambelt • TSR metal head gasket • All new seals and gaskets • Polished and ported throttle body • Chrome rocker cover • Newman 268 High performance camshaft • Ashley four Branch exhaust Manifold, comes with heat shielded tape and zip ties. • Powerflow twin round 31/2” full stainless steel sports exhaust, supplied and fitted by RSR • Golf G60 Front Calipers • Golf G60 leather steering wheel • New VW 22mm master cylinder • 280mm front cross drilled Zimmerman brake discs • 239mm rear cross drilled Zimmerman brake discs • Pagid fast road brake pads • New VW clutch • New up-rated brake lines • New Flexi Brake pipes • New front and rear wheel bearings • Weitec GT sports Shocks and lowering springs, lowered 40mm • Falcon 195 45 low profile tyres • Recon gearbox by bedrock veedubs • Mk3 weighted gear shift rod • Manual adjust clutch cable • Febi water pump and oil cooler • New Powerflex bushes throughout • New top mounts and bump stop bushes • Resprayed rear axle beam • Powder coated front calliper carriers • Resprayed coated front sub frame • Vibratech Engine mounts • Engine wiring loom rewired. • New Power steering rack • New ball joints • New tie rod ends • Adjustable camber bolts • Rear head rests fitted to back seats • Debadged Front Grill • Vented wing • 16” BBS RX alloy wheels • Chrome bee-sting aerial • CAT 1 Clifford concept 600 alarm system with window roll up, alloy wheel sensors and 3 point immobiliser. • Tracker • Delocked front door handles • VW green tinted windows throughout • Pioneer DEH-P7600MP with six disc CD changer • Eibach front and rear anti roll bars • Electric windows • Electric Mirrors • Central locking • 16V rear light clusters • 16V Tinted black front and side indicators • Big Bumpers • Alloy golf ball gearshift Now it's in for a respray in gloss black and doing an ABF conversion. Engine has been rebuilt, got a mk2 16V gearbox to rebuild and to get megasquirt working. I have no idea how to put up pictures. I guess it will have to be posted to photobucket or something with links? Chris
