Golf Mk4 1.8T GTI - Cylinder 3 misfiring
Discussion in '1.8 & 1.8T' started by bgerhold, Nov 26, 2010.
  1. bgerhold New Member
    Hi everyone
    Looking to see if anyone may have any suggestions with this problem.
    I drive a Golf Mk4 1.8 GTI (T Reg)
    Whilst in traffic last week my car suddenly started shaking badly and acceleration became a problem, where pulling away was not smooth at all. Lifting the bonnet there was alot of movement, and I suspected a misfire.
    Today I have taken into a local garage who have had a look over. Where they also suspected the common issues of spark plugs or HT leads.
    The following Checks were done:
    Spark plugs, Coils, something else noted as Ext - I guess the electric conncector going to these leads, compressions checks were also done, and a problem with the maf has also been ruled out, as the problem only occurs during acceleration and not in general driving.
    As they were unable to identify the problem they did not charge me which was nice of them, and they informed me of a few things that it could be, I'm struggling to read this guys writing so may mispell things so apologise for that -
    Tric box (module)
    ECU
    Wiring
    Injector
    They told me that it was cyclinder 3 that was misfiring (2nd from right as you look at the cyclinders from the front of the car).
    I also believe a test to get error codes was done, but no error came back (I'm pretty sure thats what he told me)
    Has anyone else had a similar problem with these?
    Does anyone know of other possible issues that could be causing this?
    Any other thought suggestions?
    Hope someone can help.
  2. nealey Forum Junkie
    Try swapping the coil pack to another cylinder and see if the missfire moves
  3. Richard Mk2
    London / Bucks
    As above, it sounds like a coilpack has gone.
    The only problem now is that you have to change all 4 of them.
    I had exactly the same symtoms as you, which started out of the blue.
    I changed the one which i thought was gone, only to have the other follow. :thumbup:
    Its recommended you change all four btw.
    Since i changed them its been fine!
  4. bgerhold New Member
    Aparantly the chap at the garage changed the coil pack. He had got a new one in from VW and the misfire remained in cyclinder 3 (there is a chance that this new one could have been faulty) but im sure he would have swapped them around just to check
  5. Richard Mk2
    London / Bucks
    The rule is change one, change all ;)
    If it still doesn't work, then maybe look at the injectors, or the wiring to the colipacks.
    Im still adamant its the coilpacks though!!
  6. Collie Forum Junkie
    Adlington Lancs
    have the plugs/wiring to cylinder3 been checked , also ensure the so called bad pack has been swapped to another cylinder to confirm its the cylinder and not the coil pack. New items can be at fault
  7. Kierenpnaylor New Member
    Alright mate have u sorted the problem yet as I'm having the same problem??
  8. Richard Mk2
    London / Bucks
    Could well be a bent valve, as I found out yesterday on mine.
    Everything was checked beforehand ( plugs,coilpacks,injectors,wiring,ect), but with the head off and the valve removed, we could clearly see a bent valve.
    Also, check your oil filler cap and the dipstick for mayo, as coolant could be leaking into one of your cylinders, causing a misfire. I've also experienced this on a previous 1.8T cylinder head.
    Dodgy ignition amplifiers on the early AGU engines can also cause misfires.
  9. Lewis583
    Lewis583 Forum Member
    If it's an AGU and the misfire doesn't follow the coil pack and spark plugs have already been changed, then I'd bet on it being the ignition amplifier.
  10. Kierenpnaylor New Member
    Will the ignition amplifier cause cylinder three nit to work at all there no spark going to it at all it had new plugs new coil pack and compression test too and still nothing it's agu engine
  11. Lewis583
    Potentially yes. Have you checked the wiring to the coil pack? It can crack/break with age and the heat cycles which can also cause the coil pack to not fire.
  12. Kierenpnaylor New Member
    Heat cycles??
  13. Kierenpnaylor New Member
    Can't see any think wrong with wiring I've even tried swooping coil packs Around and still just cylinder 3 playing up
  14. Lewis583
    The loom sits on top of the cam cover and so gets hot and cools with engine. This can fatigue the wiring loom insulation and cause shorts etc. Swapping the coil and the misfire staying on cylinder 3 proves the coil pack is not to blame and that the case is further up the line. So wiring between coil pack and ignition module or the ignition module itself.
  15. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Why is it always No.3?
  16. Kierenpnaylor New Member
    Yeh that's not a bad ideas wats the best way to replace it or get it fixed or how to deco make sure that the problem Cust I've spent load on this one problem already
  17. Richard Mk2
    London / Bucks
  18. Kierenpnaylor New Member
    Birmingham mate
  19. Richard Mk2
    London / Bucks
    If you were local I would of popped round with my one so you could test it out :thumbup:
  20. Kierenpnaylor New Member
    I'm moving to wotton under edge is that closer lol
