Hi, I was just wondering if there are any common known issues with the KBL gearbox on a Golf Mk5 1.9 (BLS engine) diesel estate? Sometimes there is an issue getting the car into gear, normally from 2nd to 3rd but also some of the other gears. There is no grinding of the gearbox just needs to be forcibly put into place. Sometimes the car will go for weeks without the problem but then come back. Was thinking it maybe the linkage from gear lever to gear box but thought I would check to see if there is a common fault. Any ideas? Thanks, Gazz.
