I have totally confused myself, have removed the Steering Column to fit new Ign Switch and in doing so removed the Spring, Lockwasher, Cup and Rubber Sleeve as per Photos now I cannot work out which item goes where !!!! Please let me know which should go where as at the moment I cannot get enough Column through the Steering Wheel to fit the nut !!
rubber bush fits to column, then you fit the ignition housing, then metal spacer thing, then spring, then lock washer:
