Hi there, My golf seems to have a very gradual brake fluid leak. Can't see any obvious leaks, but the level keeps dropping below the min mark and its very gradual - should I bleed the system or could it be another problem? Also, what brake fluid should I use? Any help /advice appreciated!
use dot 4 you must have a leak...leaky caliper or pipes/hoses its pretty dangerous so id suggest you get it looked at
