I've tried doing a search for this but haven't come up trumps. What are the differences between a GTi axle and Non GTi axle? i.e drums and discs? Could you use a drum axle and convert it to discs with the stub axles etc? If anyone could shed some light that would be great. Growler
Can probley lay my hands on a gti beam if you want one Growler, only down the road from you in Banbury mate.
If you could ianb that would be great struggling to find one local on fleabay! Haven't searched the scrappies yet tho.
if all you can get is a carby beam, bolt an aftermarket roll bar to it that'll negate the lack of std roll bar. obv should fit a matched front one though
I think that is only the VR6 .. if not.. I have a semi widetrack mk2 and didn't even know lol but it fits and with low ET 15" x 8" wheels
Sorry to highjack the thread , but I need to replace my rear drums for discs soon. If i bought a whole GTI beam, would the existing brake and handbrake cables fit?
excellent, I thought it was, but as he thoguht corrado ones were wider, cast a bit of doubt so needed an encyclopedia like yourself to confirm
vr one is a diffo part number but not sure if its wider, theres a beam measurement faq on the subject tho. iirc its sameas mk3 5 stud if so its not wider at all as it seems only some of the mk3 4stud ones were
yarp. might get away with bending the carby brake pipes till they're in the right spot to accept the caliper flexis, but ideally you want gti hard lines.
