I have two fault codes on my mk4 aum 1.8t. 17705 and 17535 Boost leak between turbo and throttle body and overfueling. My question is, would a boost leak cause the over fuelling? Also, the bosch dv is quite stiff to open with your finger, do you think this could bring up a code, I've blown through with it shut and it doesn't seem to leak but boost pressure is a lot higher than my lung pressure. Lol. Any help would be great guys. I'm not enjoying my car at the moment
I've been told to check dv. Would a faulty dv show as a boost leak? It's just strange because it started not long after I put the standard one back on
I was putting her back to standard to sell her but then decided to keep her. I've ordered a new forge 008 which should be here tomorrow. I hope it sorts it
I'm bypassing the n249 this weekend so if there's any split vac pipes I should see them. It didn't throw a code up straight away but not long after. Could just be coincidence but I hope it's the dv.
