I get this message everytime I turn on my laptop. "*.ini."is not find, Press Enter to Get Default Language ! Will not go away if i click ok press enter or anything. Can anyone help me with this please.
Can you boot into windows? I've never seen this prob before and goes to show what happens when you run AOL rubish If you cannot boot into windows then you may have to format the drive or try the recovery install on the XP disk. Although i have never got that to work.
Have you tried removing AOL 9 from your comp. If not try that. Also run a virus scanner anda few spyware scanners just in case. Also see if you can get a program that fixes problems. Like notorn windoctor. This might fix the problem for u Buzz
