It is a possibility that we are going to break my fathers mk3 golf tdi. Engine is solid, so worth me keeping. I am completely new to attempt this conversion, if anyone has done one before on here, do you have a link? Otherwise, how do i go about it? Would like to keep the mk2 clocks preff. Fuse box change? i presume mk3 diesel tank? Heard that possible to engine mixes well with mk2 gtd pieces? Also heard of a possible turbo kit for the 1.9tdi engine. making near 200bhp.. thanks in advance.
Well, you`re in the right section...a little further reading would have got you these... http://www.clubgti.com/forum/showthread.php?t=229363 http://www.clubgti.com/forum/search.php?searchid=4182333
Pretty much a straight bolt in, as you have both cars just swap it all over. Is Jetta mk2 ce2 fusebox too? If it is then even easier. For a real 200hp will see you needing, turbo either a hybrided pd150 turbo and modded rear enginge mount probably adds up to 1000 for this option or a manifold and gtb2056vk from ryanp which will add up to 2000+. On top of that you will need injector nozzles and fitting of them about 350. Then add a tune 300ish for a custom tune that you'll need for these options. But the mk3 engine with just a chip tune will be nippy in a Jetta.
