How do I mount a 36-1 tooth wheel?
Discussion in 'Throttle bodies & non-OEM ECUs' started by Gary_B, Jul 23, 2008.
  1. Gary_B
    Gary_B Forum Member
    Wirral - (NW UK)
    I'm trying to do some homework on EFI (Megasquirt) and I've come to a bit of a dead end. I have no idea how to go about mounting a 36-1 tooth wheel to the crank! Can some one please advise me?
    An even when it's on, how do I go about mounting the sensor?
    Thanks in advance.
    Gary
  2. Toyotec
    If it is a 9A or KR unit the trigger wheel should be mounted on the crankshaft damper. The pick up can be mounted via a bracket bolted to the block
  3. Gary_B
    Gary_B Forum Member
    Wirral - (NW UK)
    ^^ Cheers mate.
    Don't suppose you have any pics of what I should be aiming for?
    Thanks
  4. Gary_B
    Gary_B Forum Member
    Wirral - (NW UK)
    ^^ Interesting. Good find.
  5. Admin Guest
    I did it like this but change to this...
    It is a lighter mass and neater install.
    HTH
  6. Brookster
    M1 J40
  7. Gary_B
    Gary_B Forum Member
    Wirral - (NW UK)
    What is the external diameter of the pully that the ring is mounted on?
  8. rubjonny
