silly question how do you use fax com ive done a scan and found a few errors but how do i fix them What else can vag com do? Thanks Craig VAG-COM Version: Release 311.2-N Chassis Type: 6N2 - VW Polo Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55 Address 01 ------------------------------------------------------- Controller: 030 906 027 AA Component: MOTRONIC MP 9.0 2155 Coding: 0261204617 Shop #: 1037358719 1 Fault Found: 00533 - Idle Speed Regulation 09-00 - Adaptation Limit Surpassed Readiness: N/A Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 6N0 919 910 P Component: KOMBIINSTRUMENT MMO V15 Coding: 00441 Shop #: WSC 00000 No fault code found. Address 25 ------------------------------------------------------- Controller: 6H0 953 257 B Component: IMMO VWZ3Z0X1234088 V71 Coding: 09600 Shop #: WSC 00000 1 Fault Found: 01176 - Key 65-10 - Unauthorized - Intermittent End -------------------------------------------------------
Use VAGDASH I clear all my error codes with VAGDASH as to fully use VAG COM you have to subscribe PM me if you want more info
