Hi all! Just needing some advice of wich brakes to go for. I’ve come across some options but other suggestions are welcome -1 option (cheapest&easiest): Source some Boxster nonS Front calipers and match it with g60 discs with some custom brackets (or epytec ones) and rear std disc swap (factory drums) -2 option (improved rear bias) Same front setup but with rear 256 or 280 disc with S3 Calipers -3 option (5lug swap needed) Front vr6 knuckles with 323 lcr discs, 996 or Lcr brembos and 280mm rear disc Cheers for any advice or suggestion!
