hi guys i need some help the indicators have stopped working, im having trouble finding the faul. have you guys got any suggestion. Any help will be greatful, thanks in advance kind regards Raj Edited by: rajgohil
ok, might get more responses now...anyway have all indicators stopped working or do they work with the hazard light switch?
firstly check your fuses Going from left to right in your fusebox... check fuse 4 (emergency light system) and fuse 19 (turn signals/indicators), and replace if either are blown if these are ok... check your indicator relay (little cubic boxes above your fuses) iirc its the one on the furthest right hjas three pins on 49, 49a and 31
the hazards work but the left and right signal doent seem to work. i changed the stalks still the same, and also checked the fuses. no fuses were blown.
Replace the hazard switch before doing anything drastic, as the indicators worth thru it. Then try the relay, then get new stalks. The chunky stalks from early MK2s fit straight on BTW
i had exactly the same problem, was a fuse though, dont make my mistake and check continuity while the fuse is in the fusebox..it doesnt work that way as i found out relay or hazard switch then i guess, changing the stalks was a bit drastic wasnt it?
