This is one that has been at the back of the list of things to do, but thought it might be worth asking about.. The indicator light on the dash that is supposed to flash when the indicators does flash with the indicators, however it is alway dimly on with the ignition.. which is a bit odd! whay is this and should I worry about it?
its a problem with the hazard switch, mine did the same when the contacts inside it were a bit dirty. i pressed it on and off a load of times and eventually after a week or so it went back to normal
Except it isn't... noticed even with the haxard light switch removed the LED is on dimly when the igintion is on.. possible flasher unit issue?
