The oil pressure light comes on sometimes. I changed the low pressure switch (blue) No change. I installed an oil pressure gauge. When the car was cold it was at 65 psi. After the engine warmed up it wemt down to 5-7 psi. Am I looking at an oil pump issue?
Most VW engine oil pressure spec is 2 bar at 2000rpm (hot) 180k is getting on with it, time for a rebuild, shells will be worn.
Compression won't matter a thing to the oil pressure. Oil pump bearing tolerances pick up pipe blocked will!
