So my pb died on the way home-recoverytruck any way The 20v s gonna go in im thinking. What the best order to do it im thinkin 1 shifter, 2 gearbox /drive shafts 3 engine/exaust downpipe 4 loom Not to sure on next order to do 5 radiator(vr6)/ pipe work 6 intercooler+boost pipes Jus wanna do it in mini stages n not end up in a bigmess
Personally I'd - 1. Fit loom into fusebox 2. Brake servo & master cylinder, if your upgrading, as this will be removed to fit the loom into the fusebox, so a perfect time to upgrade. 3. Shifter 4. Hydraulic brake setup, if you're going down that route 5. Engine, gearbox and down pipe in at the same time with correct mounts. 6. Link up driveshafts 7. Connect up the loom 8. Build up your boost piping and intercooler Should be it I think. That's how I did mine
