since 1987 i oun the car (golf II kr bored to 2.0 ) i use super(leaded) fuel can i use unleaded fuel? if yes do i have to make eny mods? and if so what kind of? thanks
unleaded fuel with be fine.........try look for an unleaded fuel with an octane rating of 98. In the UK we have Shell optimax which 98.6.
You need to get the ignition timing retarded by a tuner of some sort i believe if you are wanting to run the car on 95 ron or standard unleaded, i just use optimax (98ron) car goes so much better on it. Edited by: vealige
Try it and see, i use standard unleaded in my 16v and it runs fine, cant tell the difference between that, super unleaded and LRP. Some people have reported poor performance but it will do no harm to try half a tank.
depends on what inj system you run over there,we got k-jet but youres might be fitted with ke which is u/l freindly
thanks for your posts its o k-jetronic i thing...... here we have "shell v-power racing(99 ron) I'll try it tomorow thanks again!
Like i say try the cheapo stuff (standard ul) first and see if you get any problems with it. Youve got a 50:50 chance. Then put the v-power in for special occasions !
