Could somebody with an agu 1.8t help indentfy a wire for me. Basically I'm dropping the engine into a mk2. I've pretty much converted the loom however I've found a few wires snipped and hidden away in the loom conduit. The wires are down near the starter motor but could of extended towards the oil filter housing or even further. I've got one which is black and quite thick I believe it is possibly from the oil pressure sensor. The other is a twin core wire red/green and brown/black, it's sheathed in a rubber sleeve with possibly some sort of German branding. They are in the coil/injector side of the looms and are the possibly the last few wires that come out of the rayon tape. Much appreciated for any help
best bet is strip the tape off and chase them to source. the 2 core one sounds like reverse switch, the thick one may be starter if its a red wire underneath a black outer cover
