hello I am looking to use the lupo crank sensor set up I have seen on vortex, but wondered if any one had used this set up and what part numbers did you use? cheers jimmy
Hello, Yes, I used that. Needed a 1k pull up resistor to get a nice signal. Setup in tunerstudio was pretty straightforward, as per the votes thread. Only real variable was the trigger angle in TS, but I put the trigger a bit earlier anyway. I ballparked the angle with one of my son's school protractors. Then measured the angle with a strobe and zero advance once running. Lots of people seem to have a hard time with this sensor, but few mention the pull up resistor.
