Hi guys I've now relocated my battery to the boot and I'm going to make my own tip using the badger 5 80mm turbo adaptor then into a 90 degree 80mm pipe then 80mm alloy pipe which needs to hold the N75 valve but my question is can the N75 be mounted on a small outlet pipe or does it physically have to sit inside the tip ? I no longer have the dump valve mounted in the tip so only the n75 need mounting to it
