i ve took on a project of wiring a loom for a mk1 golf series 1 .looking to run a 1.8t 20v agu with ms2. but the wiring diagram has lost me. i ve wired up oem set up before but just cant get my head round this.. the ecu is a extra efi item, this is write on the back main trigger vr generic wheel 60-2 5v sparks tach out js11 spr1 now as far as l can see megasquirt has to be run with a trigger wheel ? or can the oem crank sensor be used ? can oem coil packs be used ( bolt down type with 3 pin ) or is a different type needed ? can standard sensor be used ie , temp , maf sensor, n75 ? any help would be great thanks paul
Have a read and let me know what you do not understand afterward. http://www.clubgti.com/showthread.php?233367-Toyotec-s-how-to-integrate-Megasquirt-to-your-20vT-engine-140911&highlight=
so i ve wired in the loom now. tried to pair up with the ecu with cable connected and will not connect up via the cd provided. i think there is not a base map on the ecu . any help would be great
