mixture adjustment on pierburg 2e
Discussion in 'Engines' started by waynos, Nov 14, 2004.
  1. waynos Forum Member
    its on a mk1 1.6 cabbie gl. its different to the carb on on my 1.3 which has a 2e2 carb so i cant adjust it like i did on that. just wondered what way to turn the mixture screw (which is on top of the carb) to make it leaner. cheers
  2. mr.rabbity Forum Member
    Turn it anticlockwise.
    the 2E is the only carb where you turn anticlockwise to lean the mixture out. Just a easy way to remember.
  3. Niti New Member
    Hello,
    I have the same carb and it started consuming about 15l/100km , so how many turns to rotate fuel/air screw after tighteen it at bottom
    Thanks
  5. Niti New Member
    ah I see, I've checked a few manuals I have around and cant see a basic setting for it, just adjustment procedures with a CO meter
  7. Niti New Member
    How to reduce high fuel consumption
