mk1 golf brakes sticking
Discussion in 'Chassis' started by dubztubz, Jul 12, 2017.
  1. dubztubz Forum Member
    ireland
    Any tips on how to remove clevis pin clip at servo
    Can't remember how I did it before
  2. dubztubz Forum Member
    ireland
    got out servo&mc yesterday and measured from back of servo to middle of clevis pin 130mm.did spot that when push the rod/plunger in at the back of the servo its catching on something and no always letting you push it in
  3. rubjonny
    thing is if you took the master cylinder off the servo and your brakes are still locked its nothign on the servo side, its the hydro side at fault
  4. dubztubz Forum Member
    ireland
    Only loosened the M/C nuts few turns off the servo.could the servo push rod been stuck in the mc
    What else can cause the brakes to come on
  5. rubjonny
    next time fully release the mc so the servo is definitely not pressing on it, see if the brakes release :)
  6. dubztubz Forum Member
    ireland
    Can you fit 23mm master cylinder to mk2 9" servo
  7. rubjonny
    yes but needs mods to do so if you're thinking ibiza/focus one. theres no need for the brakes you have though.
  8. dubztubz Forum Member
    ireland
    Have 23mm 4port I took out vw t4 1.9 ft before I broke it.found that Mc I had in the car is only 20mm 4port.ive 256 brakes up front and mk3 on the rear.23mm looks the same as 20mm what mods are involved I wonder
  9. rubjonny
    ah t4 is same fitting as mk2, should go straight on. since you have it swap it over and see how it is.
    worst case you find pedal travel is too short with the 23mm but original problem is fixed all you've wasted is time and fluid, just buy a new 22mm and be sorted :)
  10. dubztubz Forum Member
    ireland
    Still had the problem so I took out servo&mc the last nite to check.i had 130mm to middle of clevis pin.it was a 20mm Mc on the servo.when you press plunger in on back of servo I felt it catch,picked up another servo yesterday all seem good with that one.i wonder is it the 20mm Mc that was the cause of brakes
  11. rubjonny
    if the servo is sticky that sounds like the issue for sure
  12. dubztubz Forum Member
    ireland
    Yeah when I push the rod on the ground on the servo sometimes it's smooth and then you could feel it catch.replacement is fitted and brake linkage greased.just to fit master cylinder tomorrow and bleed the system,the plunger arm on the axle needs to be held back towards axle is it
  13. rubjonny
    yeah imagien the way it moves as the axle is pushed upwards by extra weight in the boot, clamp it fully in that direction :)
  14. dubztubz Forum Member
    ireland
    Update
    Second hand servo fitted along with 1998 t4 23mm master cylinder
    Pressure bleeder left on at 5psi over night,brakes bleed the morning then drove 20miles +
    All good so far no sticking brakes.good pedal and sharp response ??
    Thank for help guys
  15. rubjonny
    lovely jubbly :)
