As of yet undecided if the shift light i made while i had the dash of the golf out is uber cool or chavtastic.....its run from the megajolt ignition and a small relay controller to prevent all leds lighting at the same time, the rev limit at which the colors is adjustable from 500 to 10k rpm...and it can be seen in the day light no problem..peripherally.....auto correct saves the day.. http://vidmg.photobucket.com/albums/v43/JOCONNELL100/20141023_125004_zpsrhvvjbye.mp4
I went for a drive last night after dark.......an excellent addition to prevent engine damage , you;d never hit the limiter again..you live and learn.... The RGB led strip i had already ,you can make a few different colors from this but it was an experiment so i didn't what to spent time with a controller to make better colors.thankfully , however an oil pressure warning light.....
