Evening all, Been busy so not spent much time on the MK1 however this weekend I tried to start it again having fitted a completely new fuel system incl tank (the old one was weeping on a seam and the breather connection was rotten) all new flex pipes incl breathers etc, new 8mm copper flow and return pipes and new in line pump fitted and re-wired with 17 amp cable and in line 15 amp fuse. ................. Turned it over this afternoon and it still wont start Its got a spark (regular and reliable), its got a 6 bar fuel pump from a reservoir fed by a lift pump. If I use the relay the lift pump runs for a couple of seconds and stops and wont run until the ignition is switched off and left for a few seconds, then when switched on again the lift pump runs for a couple of seconds and stops. The main pump runs when starting the car and turning it over and stops when the ignition is switched off. I have fitted a hidden in-line switch and this tests as fine. I removed the relay and bridged the terminals and the lift pump runs continuously. There is fuel getting to the rail (I removed the return pipe and it spat it out) I did turn it over a while ago with carb cleaner down the TB and it fired so I`m sure its a fuel issue. 1) Possible the main pump isnt pressurising properly (unlikely) - should I invest in a fuel pressure gauge? Anyone got one I can borrow? 2) Possible PRV failure on the rail (unlikely) however will the PRV be affected if the vacuum pipe is faulty? - it looks old and battered but I believe it only raises fuel pressure momenatarily as the throttle opens and vacuum increases? 3) Possible injector trigger failure? I put a voltmeter on each of the 5 terminals and got 0.17V on each with ignition on but I`m not sure what to look for when it is turning over. I still dont know why the lift pump starts and then stops with the relay in!! Help!!!!!!!!!!!! __________________
what pumps do you have a lift pump and a main pump? if so both should run at the same time when the key is turned for 2 seconds if your only hearing the lift pump then that could be your issue
When the relay is bridged the lift pump runs continuously and when the ignition is on the main pump runs. The lift pump must be filling the reservoir as the main pump is pressurising the rail with fuel (but I dont know to what pressure) and is a brand new 6 bar Sytec pump. I just had another look and seem to recall that the coil triggers the injectors? (I`m running a TCI unit with coil instead of the original coilamp as they are unreliable) Can anyone more knowledgeable than me (Rubjonny ) prompt me again with the correct wiring to the coil although I`m sure its correct. Also - the engine has no water in it yet as I want to start it for a few seconds before I fill it. I dont think the sender will stop it running if its empty but I may be wrong.
you say you have a spark while cranking so id say you have the coil correct as for the fuel pump if your getting fuel to the rail then thats good are the fuel pipes around the correct way ? im guessing you have checked all the silly things like plug leads around the right way ect but never hurts to prompt lol
Is it on the ABF digifant or an aftermarket system? Are the spark plugs wet or dry? When I megasquirted the track car, you could hear a 'tick tick tick' when it fires the injectors. Any sounds from yours?
sounds to me like your fuel pump wiring is a bit bodged, you have the lift pump wired separately to the main pump which isnt right. wire the main pump to the same wires as the lift pump, then work from there. the k-jet fuel pump relay needs a rev counter signal to work from the coil, so this could explain why it wont work when cranking if there is an issue there. as mike says, exactly what engine management are we dealing with here?
Hi John You wired the loom for me and I have a thick yellow and red supply you provided that tees off and supplies to both pumps. Both circuits were pre-checked for full voltage, resistance and continuity. Its got the original (non-immobilised) ECU with the original coil and TCI as per your recommendations but I seem to recall that energising the coil triggers the injectors? I consider the spark plugs are dry. PS: I`ve installed the fuel system as per the diagram below but with the lift pump in the tank Another aspect is that the pump is piped wrongly (Sytec do not include instructions) so there are 12mm and 8mm push fit connectors and I`m positive its the 12mm in from the reservoir and 8mm high pressure out - or am I wrong as I cant see a 12mm out supplied by an 8mm in will work? Another aspect may be the wiring but the smaller ring post terminal has a (very small) plus on it so I assume power and the other larger ring post terminal doesnt so I assume earth!
yeah but it sounds like the main pump is wired differently to the main pump, i would get under there and have a look at it. both pumps should be wires in parallelelelel so if 1 pump is going, the other always should be as well! iirc i only supplied the pump output wire with a spade on which you needed to splice your old pump wiring into, which seems to be ok for the lift pump. but the main to me sounds liek it has another feed for some reason. either that or the pump is dying? anyway, i remember now its an abf, so the fuel relay you should have is a 67, 80 or 167 which is fully controlled by the ecu. the injectors are also controlled by the ecu, they do get a live feed from the fuel pump relay but they are earthed by the ecu. both the fuel pumps should prime when key is first turned (not every time though ecu is quite clever about this, it only does it the 1 time then wont again for a bit) but it should always run the pump while the engien is cranking over on the starter. if it isnt that suggests that you have lost your crank sensor signal, or maybe the starter live feed? there should be a 12v sifgnal to the ecu while the engine is cranking over from pin C18, or D24 depending how i did it. if wired to C18 then there will be a red wire with a spade on it, which needs to plug into another spade hanging out of pin C/18. not to be confused weith the other red wire which connects to pin N or spade hanging out of E/14
Hi John The pumps are wired in parallel from the red/yellow connector you provided so have a common feed. I`ll check both run with the relay bridged as I can only hear the in-tank pump. It has a brand new OEM 167 The lift pump certainly primes when the ignition is on but only runs full time when the relay is bridged (I assume therefore that the main pump is the same as I hear it prime but it is near silent when running) You are correct in that if the ignition is turned on the pumps prime and if it is turned off and on quickly they wont re-prime themselves unless a few seconds is left before trying again. The ECU clicks when the ignition is turned on and off to the first position before starting it. The ISV also clicks - is this the starter live feed? I`ll check all pins from the ECU as you suggest and report back and check all wiring (again) from the ECU to the engine loom. BTW.................if the engine earth below the distributor cap is poor what effect would this have? I seem to remember something about it however I am meticulous in preperation so would be surprised however I might run a dedicated wire back to the battery but I`d be interested to know what it affects. How do I know if the crank sensor is FUBAR? I have a spare s/h one so if fitted will it generate a signal somewhere I can measure?
ok yeah, just double check that both pumps do indeed run at the same time. if they dont, then something isnt right! you mean the ecu relay clicks yeah? the isv shouldnt click, it should buzz. it can be very quiet so you might just have to touch the thing to feel it vibrating. this isnt the feed i mean though, there is a feed to the ecu that is only live when the engien is cranking over on the starter. i cant remember if i put this on a spade plug behind the fusebox as per factory mk1/2, or just spliced it to the chunky red/black wire? You should have 2 red wires back there, 1 iirc i put a big yellow spade on which goes tyo plug N, this is for the injectors. the other is the starter live, which either has a spade on the end and runs to the spade coming off C/18, or i spliced it to the chunky red/black wire at D/24. the earth below the dizzy is for the dash and some of the ecu sensors, so this needs to be good! did you remove the engien wire loom and check it, the one that is left on the block i mean once the bay loom is disconnected. im not sure how you can test the crank sensor, but if you look at the one on the engien if its all cracked and frayed that means it needs to be replaced. sometimes the ecu will flag up a fault in vag-com if its faulty, but you can also get a false positive flag in vag-com if you check the codes when the engine isnt cranking over! so thats not much use
12mm in and 8mm out sounds right to me - larger connector on the bosch pumps is on the low pressure side. Assume the ECU has a part number ending in AB? Apologies if this is going over old ground, but worth checking. As you suggest, I'd start by checking that both pumps are running. You've got a spark, so if it's not a fuel supply issue, that narrows it down to the injector signal for me.
one thing that would be nice to confirm is if the starter feed has any impact on the fuel pump trigger, or if its just down to crank/hall input. if not, whats the starter signal for?
does the rev counter move on cranking if not then you dont have a tach signal meaning you wont get power to the injectors or fuel pump relay
Thanks chaps.......................for now Thats a lot to think about, I really do appreciate your time on this. I`ll have a busy Saturday ahead of me and will methodically go through all the suggestions above and get back to you (hopefully with good news) Once again, thanks.
Hi John I`m out here in the garage as frustrated as hell. Both pumps prime briefly and stop when the ignition is turned on. They are wired properly and in parallel. They both run when cranking and stop a half second after stopping cranking and run 10.6 volts (assumed to be due to the cranking) so its not the pumps. You fitted a blue/red wire piggy backed from the large red/black pump supply wire that goes to the ECU relay connector block. This is momentarily live as the pump primes and then has no voltage. When cranking the engine it is powered and shows 10.6 volts (assumed low due to the cranking) and goes off when the cranking stops. I put a continuity tester from the engine earth below the dizzy to the earth cable at the battery and it is continuous with negligible resistance so assume it is ok. The rev counter jumps when cranking so it is seeing a signal. I get a big reliable white spark in sequence to each plug so its not the rotor arm or leads when cranking so assume the crank sensor is ok?? Or could I be wrong? I do note that each plug sparks once when the engine is turned off. The plugs are not wet and dont smell of fuel. I dont think its a timing issue. I did change the cam belt but rotated it twice and all marks aligned properly. The ISV definitely clicks - noticeably and audibly. Note that there is no voltage to (I assume) the positive on the injector plug (the larger red wire of the 5 wires) or any other of the wires when ignition is on and there is no 12 volts when cranking. It must be the injector trigger signal or lack of power nto the injectors but am now completely stumped! What voltage should I see at the injectors? Any thoughts?
To check the wiring is correct................ ECU relay 53 is wired a follows Small brown/black to connector pin 6 (relay pin 85) Two large red to connector pin 8 (relay pin 87) Blue/red feed from pump supply to connector pin 2 (relay pin 87) Blue/red jumper from connector pin 2 to connector pin 4 (relay pin 86) Lambda relay 30 is wired as follows Red permanent live from fuse board to connector pin 2 (relay pin 30) Earth on block above fuseboard to connector pin 4 (relay pin 85) Yellow/black to connector pin 6 (relay pin 86) Black/white to connector pin 9 (relay pin 86a) Black from fuseboard D2 to connector pin 8 (relay pin 66) A 167 relay is in position 2 for the pumps. ********************** When checking against the ECU plug wiring charts............. The only brown/black is ECU pin 28 - Lambda sensor relay (pulls low) (k94) Is this in the correct relay as its in the ECU relay? The yellow/black is ECU pin 23 and designated as going to engine control relay pin 87 however its connected to pin 86. Is this correct? The black/white is ECU pin 9 and designated as going to engine control relay pin 86a which appears correct. Sorry for the fuss but I`d appreciate a few pointers, thanks.
The yellow/black is ECU pin 23 and designated as going to engine control relay pin 87 however its connected to pin 86. Is this correct? what relay is this fuel pump by any chance? if so id say thats the issue a wire around the wrong way have you tried putting it on 87?
Sounds like a good diagnosis to me. I don't know enough about the modern setup to know how the injector trigger is fired, but I'm sure the other guys commenting on the thread have that bit. I'm not sure if the trigger for these will be on the power or earth. Have you got a good earth on the injector loom. I think the Megasquirt setup triggers on the earth side, with a constant live. Can't remember for sure though.
With a faulty CPS the engine won't turn over. You hear the pumps prime but the spark generated at the coil is sent to earth (at the dizzy iirc). There is an audibly tick from within the bay. If the engine is cranking then you shouldbe able to safely rule out a CPS problem.
The ECU earths the injectors I am told so I would have thought you`d get an ignition/ECU live to them all and the ECU would trigger them in sequence. Its where the power to them comes from I`m stymied at as there is a pin on the ECU that shows a connection to the main red on the injector plug but also all 4 injector wires. There are two 1.0mm reds connected into the ECU relay pin 87 so I assume its those I need to investigate. Thanks fore the help (and support) If you see a large black smoke cloud over North Herts later today then you`ll know I decided to set fire to the bl**dy thing
