Looking for someone who has ETKA to do a search for Part No. 027 105 243 if you have a couple of minutes... Hoping its a standard UK spec 16v crank pulley... This is the crank pulley that the guys at Eurospeed in Canada use for their bespoke 16v DTA crank trigger wheel & position sensor bracket set up...Not sure if the Canadian/US spec pulley is the same what with their cars having air con etc etc Hoping this set up may spell the end to B6 chewing crank sensors on a regular basis
Ah! perfect opportunity to test my copy of etka! Apparently its : vee belt pulley with vibration damper (for kr/pl engine) Edited by: Seraph
sounds like I only need the trigger wheel itself then (presses onto the crank pulley apparently) Cheers Seraph
