Hi guys and girls, Can anyone tell me what size pipe i would need to get out of trouble? The pipe the runs from the fuel filter to the fuel pump ( supply) Has rubbed its self a hole! So now leaking out derv, and sucking in air! so much so it will not run! it is a few years old now however! So the pipe comes off the filter (rubber, turns to clear plastic over the cam cover, then back to a small piece of rubber before the union on the pump). As a quick fix can i do the whole length in rubber, and what size would it be?? 6mm?? Cheers Luke
the rubber pipe is probably 7mm i/d lookign at ETKA, see if the 2x outlets on the fuel filter that side are the same. if so, thats the right size part number is 191130309em, VW classic are doing it again can order via heritage website: https://www.vwheritage.com/vw.cfm?a...assicSearchText=191130309E&country=GB&lang=EN
