really desperate for some mk2 golf 1989 gti 8v fuel lines as vw discontinued them in january! i have managed 2 get hold of the return line just need the feed and the rubber hoses that attatch to the lines!! cant seem 2 b able 2 get them anywhere does anyone no if anybody who has got any or if they can be made?? Thanks! James!
yeah could b an idea!! going 2 go 2 pirtek 2mo 2 c if they can come up with anything! just nobody seems 2 want 2 deal with fuel lines!! thanks 4 the advice j
I used injection hose, its not ideal though as it needs to be an S shape. with careful routing and some plastic clips its fine though!
i can form any size fuel line into any shape/length - can insert barbs to join to felxi hose etc.. all i would need is somesort of a drawing with lengths and angles and know what fittings to have in each end. this would be of PA12 construction with PA6.6 barbs, or galvenised unions
Find the diameter of the metal pipe you need and ring the Vauxhall dealers, the Calibra (only one I changed them on so I’m not sure what else they use it on) uses metal pipe for the fuel lines and comes by the meter, don’t think it was expensive from memory
how heavy is the line, I'd be worried about having it hanging about there, plus the flexing issues. the line needs to be about 20-30cm long and bent in an S shape to avoid the master cylinder, inlet boot etc
all sorted lads thanks 4 the advice went to a company called ahgabridge motor factors in strood kent they sorted me out some fuel line, clips and some rubber bends etc!! cost me about a tenner which was a bit of a result!! thanks j
