Hi all, Need help again I’m afraid! I’ve just changed the front suspension on my 1995 2.0 8v and wondered if the top strut caps should sit like this or have I cocked something up? That sat like this before I changed them but I thought it would be rectified when I fitted the new ones! I fitted some coilovers by the way and I’ve only done the fronts so far but man they’re bouncy and there feels to be a lot less grip. Maybe once they’re all done, set up and camber etc is sorted it might improve!
Thanks Tristan. No, they are only height adjustable unfortunately and I’ve only dropped them 25mm. They are ARC Climax-1 coilovers from Japan. I’ll get the back end done and see what happens!
Never heard of ARC on a mk2, but definitely don't write them off till you put a few miles on them , and get the camber and toe set.
