I'm researching to have TDi PD fitted in my MK3 GTi. Does has anyone build this on MK3 Golf before and thread on this site as I could not find it? I'm looking into buying rear damaged VAG donor car and swap everything into my Golf to save cost. Will the 1.9 TDi PD engine and 6-speed box slot on the GTi mount? Or will need sub-frame from donor car? I have seen TDi PD in Mk2 Golf, but not mk3. Any info will be great regarding to TDI conversion
I've done a pd 150 mk2 with a 6speed and mounted it on the subframe just need to cut and move the gearbox mount so I'd do the mk3 the same I'm just started a mk3.5 20vt with a 6speed and I'm mounting that on the subframe as well
