hi ive got a mk3 golf gti R Reg. it was runing fine then went to use it one day and it wont start atall. it cranks over but no spark and the fuel pump dosnt come on. any idears.
ignition coils packed up, fuse gone for the fuel pump, check all connections & fuses, what engine do you have?
ive checked the coil thats fine and also the fuses are fine. the engine is the 2.0 8v agg. im usein a the same block in my mk2 golf aswell. also ive been told it could be the key and transponder could be ****ed or the immobiliser anit working right.
if it was coil, pump would still prime. if it was factory immob issue, car would still prime and run for a few seconds. sounds like the crank sensor to me.
hmm actually it would still prime, so im talking cack there. ecu relay or ign switch/wiring problem perhaps? check ign switch wiring, lot of alarm installers like to muller the wiring there to install things
can you get some one near you to put a code reader on it? put a shout out for a code reading if you were this way i'll do it for you
