hi i have just converted from 1.4 to 2.0 8v and got some plugs what our not plugged in and not sure what they do and the immobiliser is cutting in i have went to install a defeat chip but the wires had already been cut for the immoillser wiring so now not sure what wire is what this is immobiliser wires http://s1164.photobucket.com/user/k...73986116115662_n_zpswdi8brkt.jpg.html?filters[user]=143335922&filters[recent]=1&sort=1&o=2 http://s1164.photobucket.com/user/k...72825265968746_n_zpstpnnan3z.jpg.html?filters[user]=143335922&filters[recent]=1&sort=1&o=5 thanks
the problem is your immobiliser box isnt connected to anything. the grey/white wire should be connected to the ecu diagnostics wire to pin 43 and the grey needs to go to the diagnostics jumper block above the fusebox so you can communicate to it and the ecu with vagcom. 1 - diagnostics port wires, goes to diagnostics jumper block 2 - immobiliser box wires 3 - jumper blocks for various feeds, black ignition live, white door pins, blue VSS 4 - dont recognise, ignore for now 5 - vss feed for something. ecu most likely, goes to blue jumper block above regardless 6 - possibly connection for heated mirrors, ignore for now anyway
my immobiliser box wires all the plugs have been cut off by previous owner and a diy defeat chip was installed but i took it out as one of the wires had broke so i brought a new one and went to install it but not sure what wires do what for immobiliser box now
