I have a Golf mk3 on a L (94) with the AAA VR6 in! problem is whenever i floor it, it missfire's/ drops to 5 cylinders?!?!?!?! it runs on tickover fine and if you pull away and feather the accelorator it drives fine but as soon as you give it more than normal it holds back! so far i have cahnged....... coil leads plugs ecu relay all the usual things! any ideas or anyone had the same problems? cheers guys n gals
