Hi im new to this site and just got my first gti mk4 1.8 t year 2000 took for test drive but never noticed a knocking sound when i go over bumps in the road can anyone give me advice on what it can be and is it safe to drive?
First thing is for daft and safety week is check wheels are tight Next up I would look at inner anti roll bar bushes and drop links from anti roll bar to bottom arms, Also check bottom are inner bushes (rear one goes) and lower ball joints for play
it will be the drop links i changed my ones 6 days ago bought a pair of uprated solid metal ones off ebay for 20 worth every penny
The common knocking noise on Mk4's is normally a worn "Dogbone" gearbox mount. You'll get knocking, especially on pull away, and another sign is excessive engine movement. Open the bonnet and get someone to rev it ( if its not cable throttle that is ), and see if the engine has a lot of movement.
On my previous Mk4, I had knocking noises. The causes were - Rear beam bushes, Dogbone bush, and wishbone bushes. When these were all replaced it was like driving a new car. Rear beam bushes can be very noisy when they go. Have you checked for movement on the engine when revving ?
