Mk5 GTI Hissing
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by jamesgolfguy, Mar 14, 2012.
  1. jamesgolfguy New Member
    Hi all, I am experiencing a hissing noise from under the engine bay which I only get when accelerating? Any help would be greatly appreciated.
    James.
  2. nealey Forum Junkie
    First thought would be a boost leak, is it down on power, any warning lights on?
  3. jamesgolfguy New Member
    Reply
    No there is a slight lack of power but hardly noticeable and no lights have come on on the dash board, I would like to try and avoid taking it to the main dealer because they would just cost me an arm and a leg.
  4. Dan W
    Dan W CGTI Regional Host
    Penryn, Cornwall
    If the leak isn't causing any measurements to go out of range then it wouldn't necessarily cause a fault. Best bet is to get someone to give the throttle a stab while you listen under the bonnet. Hopefully it'll be fairly easy to spot
  5. jamesgolfguy New Member
    Many thanks will give that a try and keep u posted.
