Does anyone know if the following is straight forward to fix or a PITA? 1st picture is from the piping from turbo, 2nd is the piping to the intercooler (which I assume is mostly due to the 1st picture!) TIA Lhasa2008
Looks just like my Ibiza PD TDI The hoses just clip in and out Ease the retaining clip out noting exactly where and how it sits first then pull the pipe out. Inspect the flutes in the aluminium hose ends for excess wear or wether they still engage well against the clips. Inspect the clips for wear If the pipe is still ok, you can get new rubber seals for the ends The clips are cheap If the pipe flutes are damaged, pipes are typically 50 each, maybe more for the one off the turbo
