is that a '16v' badge on the back (below the 'gti') or is it a 'vr6' badge? can't really make it out.
didn't corrado's have red vr6 badges, in the same style as your 16v badge. i think if you've got a vr6, you've gotta flaunt it. get some vr6 badges on it!
No, i'll keep the 16v ones. Its even subtle with your foot down at the moment, only 133bhp, i have an air intake problem that should be solved pretty soon.
here's 1990's feature i did on the VR6 site - http://www.vr6golf.co.uk/article.php?10.255 Edited by: VR6Pete
It looks a bit different now Kev, i have a corrado vr air box and a big tube from the head breather to my inner wing. UNITL SOMEONE SELLS ME AN ORIGINAL BREATHER PIPE THAT GOES TO THE BIG AIR INLET TUBE. ^^^^^^^^^^^^^^^^^^^^^^^^^^ Not an add, honest Edited by: 1990
Nice car!! Shame its only running 133 BHP. Is it an easy problem to fix? Means ur running less power then a standard 16V
If i knew how to use vag com it might. Its running a lot better now right to the red line (before only 5000rpm) I have fitted a corrado vr6 airbox and inlet track? (rubber tube to throttle body) and its made a good difference, its running realy rich though.
