engines done 8.8, thats good mate, I thought it could be in the 8 or 7 second group. Whats the plans for the dragster, does it have to have an engine rebuild before a full power run?
i blew a piston / rod / and crank last time out needs a rebuild http://www.dubscene.co.uk and http://www.taylormachine.co.uk to the rescue then it should last a season without touching haven't done a full power run yet, cause it scares the bejesus out of me
2366 type 4 flatfour 586bhp 71mm x 103mm stroke x bore pauter heads with 52mm x 47mm titanium valves. 750 holley feeding a t04 garrett running 32psi co2 charge cooler (sometimes) msd ignition 4 speed manuel box 17 by 2.5 inch front slicks 31 by 11 by 15 rear slicks and a parachute
it's got a manual box? I dont suppose having to shift 3 times is easy when accelerating at that rate! Dont other dragsters have autoboxes? Sounds like a lot of mental fun though, bet a lot goes through your mind on a 1/4 mile run. How much has it cost to keep it running?
has any one got specs/pics of russ fellows's beetle. I've seen it go past my local shops wheel spinning, I hear it's a 911 turbo eater
