Couldnt find pads for an Audi with Girling 60 two piston calipers in my local factors and I didnt exactly want to pay Audi over 100 for pads. I noticed a 98 Range Rover 2.5 DSE at work with what looked like Girling 60 calipers on it, took my calipers to the factors measured the carriers and they looked like the pads fitted ordered a set and yes they fit perfectly. The Range Rover also uses a 25mm thick disc just like the Audi's so a Golf G60 280 disc should be fine as there only 22mm thick. Part No : BW641 * Description : Brake Pads * Manufacturer : Brakeworld * Unit Of Sale : Boxed Set * Description: 4 PLAIN PADS * Dimensions (mm): 145 X 66 X 19 BW641 is suitable for the following applications LAND ROVER DISCOVERY II 2.5 TD5 DIESEL 99-04 LAND ROVER DISCOVERY II 3.9 V8 PETROL 99-04 LAND ROVER RANGE ROVER II 2.5 TD (LP) DIESEL 94-01 LAND ROVER RANGE ROVER II 4.0 V8 (LP) PETROL 94-01 LAND ROVER RANGE ROVER II 4.6 V8 (LP) PETROL 94-01
Gsf sell them for 35 For the twin pot audi s2 calipers they are pagid pads, i think part number is 64580 I just got some the other day arrived within a couple days
need to order caliper carrier to hub bolts first to check but looks ok, mocked them up inside one of my allow wheels I'm refurbishing and spin freely too just hoping they fit im my ats cups which will be my "winter" wheels or they will have to go
Havent fitted them yet but planning on golf g60/rallye goodridge 6 line set, fitting them to corrado 16v (9a) hubs and golf 60 synchro 280x22 discs
These just sweep off the inside of the disc. Audi disc's are 276mm I used goodridge hoses on mine, but im pretty sure std hoses will fit fine
So............. do these Range Rover pads sweep the inside of the disc like the Audi's or are they clear???
yeah they sweep the inside of the disc by about 2 mm at the most but I am using cheap pads and discs for now will change to VW or Ate power discs or similar later and better pads
i ended up ordering audi s2 pads... here are the two pads: Audi s2 pads: Notice the spring and the "nugget" that holds the pads.. So it can't move.. Ranger Rover ones:
HELP!!! indesperate need of 4 new caliper sliders to fit my Girling G60 calipers to my mk1 (they did not come with my carriers) does anyone know what size these are as Audi/TPS can not provide what I need and looking into alternatives
After a bit of searching through a few online catalogues i seem to be getting an oe number of 171698447 or 171698447a. There's some on Ebay for sale Edit : http://www.ebay.co.uk/itm/VW-GOLF-M...KIT-171698447-A70-/200834092582#ht_2273wt_905
