i got given a dry nirous oxide system's kit which iv fitted to my mk1 golf 1.8t, the engine is a bam with a big port head, it runs a qpeng management and should produce around 260-280bhp. My first question is how much more bhp can that set up take? my second is, the kit came with 4 jets a 32, 34, 36 and a 42 which one should be in the nitros jet for a given power my third is, which jet should be in the vacuum pipe to control the fuel im not sure if these jets are suitable for me at all any help or advise would be great thanks rob
You need to read this as most if not all of your qstns should be answered http://www.clubgti.com/forum/showthread.php?t=114993
nitrous no its a nitrous oxide systems kit no: 5200, i think its an american kit, but its quite old iv got the receipt for it from 1998!!
you don't have any jets in the vacum pipe, dry system is on good for 50bhp extra unless you have a switchable map on the ecu which will increase fuel when the gas is activated. post a picture of the kit 32 jet is arround 50BHP with 600psi bottle pressure Calculate jet size here - http://www.dynotunenitrous.com/store/Scripts/Jet_calculator/nitrousjetcalc.asp
nitrous pics here are some pics, [/IMG] as you can see from the instructions it does have a jet in the vacuum anybody seen this system before?
