Hi All, Need some assistance, basically i have a mk4 PD130 and the car has loss power, I got it on my diagnostic machine and there is a suspect cylinder no1 injector is playing up. What is the best way around this? All help is really appreciated Thanks
Check Injector loom plug right side of head then test from plug to injector you will need to remove rocker cover to do this (looms give bother) If injector is dead pull it out and replace it ..dead handy ....bring it round to full lift on the cam when fitted then turn in to you feel a slight bind then turn out 180 degrees and lock her up ..then check the rest while your there
