Hi, does the nodiz pro replace the standard abf ecu, I already have just need to know for the wiring, will be running bike carbs, Cheers
Nodiz is mappable ignition, as I understand it. It should replace the standard ecu in function, not pip for pin. I would wire it independently and leave the ECU/OE harness in place should you decide to revert back Jon Let us know how you get on with the conversion, I did toy with going nodiz to match twin carbs
