What should be oil pressure on hot idle 760rpm? engine is 1,8T AUQ I measured 1,4Bar at hot idle, is it enough?
but flashing oil pressure I bought new oil pressure switch,new oil pump and no difference [:^(] car is golf mk2, engine AUQ
I tried firstly Mobil 1 5w50, and secondly Castrol 5w40 and no differences from swap I drove only about 30miles, because Im afraid that destroy the engine [:^(]
cold idle about 1400rpm: 6-6,5bar hot idle about 720-760rpm: 1,4bar about 1000rpm: 1,8-2,0bar about 6000-6500rpm: 6bar about 3000-4000rpm: about 4bar
Yeah, I think I'm having those numbers around those RPM. I had a sensor failing on me, and it was beeping. Are you using the sensor for the mk2 cluster? HOw do you have this setup? The beep/flash only comes over 2700rpm?
the flash comes only at hot idle (about 720-760rpm) Im using sensor original for AUQ engine through the relay to the mk2 clusters (but I measured groung also directly on the sensor) what setup are you using on yours mk2 20VT?
Deffo electrical issue it seems, i think you can relax and drive your car normaly until you trace the fault
Well, IF I'm not mistaken, I used a mk2 sensor for the oil pressure as your cluster will be the one activated by it. The ECU will not read anything from the OIL, from what I'm remember (can be wrong of course). Have you had this working before, or it's a fresh new install? Again, I'm not 100% sure of how it's setup on mine.
this working after install 20VT into my golf mk2 today Im used sensor from golf mk3 engine 1,9TD, on the sensor write 0,75-1,05bar..with this sensor is all ok without flashing, but i dont how that this sensor is for 20VT engine good
