Had this code latching for a while now and have tried various options. It suggests a ECM internal issue however I have had the ECU out and Bench tested it, serviceable. Anyone seen this before? One of the symptoms is the cruise control doesn't work! Otherwise everything tuns fine
Yeah funny you say that, it was in for a cam belt change and the garage did something that has now rectified it!
A faulty brake pedal switch can cause these type of errors and weird unrelated electrical faults. Genuine one from vw is about 18 ish. Worth replacing if you're experience similar issues. Has a similar issue on the missus Polo recently.
