Right then... As there were a few bits and pieces missing on the AGU i bought, im in need of some part numbers for the following parts - * 4 x Banjo bolts. The ones which fit into the turbo oil lines and water lines. (not sure if they are the same or different ?). * Rear engine bracket bolts * The roller cambelt tensioner and alternator tensioner. Im sure there is more parts i need from the stealers, so will update with them. Just need the above parts atm really. Cheers
Mk2 bolts will be fine for the bracket (if they are still in decent condition). There`s two types of banjo bolts used in a couple of locations (No.s 31 and 41 on the diagram) 31- N 0210742 41- N 0210715 There`s a couple of different tensioner setups, and I`m not sure which one suits the AGU, but the dealer will easily tell you which you need. Bracket bolts (if you need new ones) are; N 10195301 (short one, 35mm) and N 0195042 (longer, 45mm)
Cheers Stu and Mushy for the detailed replys, much appreciated Thats great. I can get these ordered up at the local dealers now. Hopefully the bolts wont cost too much. I managed to get hold of the coilpack bolts & TB bolts from LMR on ebay. They look good too Will update as soon as i get an idea of what i have missing. Need to start building this engine up soon.
eye the alternator tensioner wont be cheap from vw about 70 as jon has said you should get a new one on ebay for about 30 may even be the same make as the vw one
Need some more part numbers please * The turbocharger mounting bolts * Oil return pipe flange bolts Cheers
The oil return flange bolts should be in my first post 11 and 25 Will have a look for the turbo ones when I get in later
Im after a MAF (air flow metre) for my AGU engine. Can anyone confirm if this is the correct part number for my engine - 06a906461d Cheers in advanced
