this is one problem i have changing colours do you quick mask it out first or do you use another tool?
i always lasso tool especially in a photograph then just mess around with the desaturates and stuff in Image > Ajustments play round with the tools in there osme work better than others at different times also in an image like that you could probably use the channels in the channel box (where the layers are look at the tab and you will see channels this relates to the RGB channels Red Green Blue you can do selection masks and all sorts inclusing just selecting one colour etc but its all a little too much for me to be bothered with at the moment when i have some time i will look into it in more detail
yeah ill have to learn how to use the lasso tool how does it know what you want to select? like how does it only select the colour you want to change? i understand the colour change. should have made myself a little clearer yeah its selecting that i need to know. i usually just quick mask.....but thats not so good when you want to be accurate
