I need some track wheels and have found some 15's Will renault wheels fit a mk2 golf? Are they the same offset? I know beemer ones will.
Depends on which Renault they're off! A quick scan of the net brought up the following; Model Clio, Megane, Laguna, R19, R21, Espace P.C.D. Offset C/Bore 4 x 100 35...38 60.0 Model R21 Turbo, Laguna V6 P.C.D. Offset C/Bore 5 x 108 35 60.0
also there is good chance you will need some spigot rings to adapt the centre bore to the smaller VW size, they work fine without but you get a vibration above a certain speed as they arent centred as accuratly as they could. I ran 16v clio wheels on my mk2 for a while and they were great..
I've been running phase 1 renault 19 wheels on my Passat for about 3 years. I dont get any vibrations as long as I do up the wheel bolts evenly. My bros Mk2 golf is running the same wheels with no probs (for some reason I ended up with 8 so he "borrowed" 4
