POWER MAXED Cleaning products and Lubricants Power Maxed is a revolutionary new range of automotive products. Our only aim is to be the best, nothing comes before that. We have developed our products not just to be better than others but to be the best they can be. As far as we are concerned only quality counts and once you have tried Power Maxed you wont want to use anything else. When we make a product only the very best is good enough, that means we source and use the very best ingredients and then with years of experience behind us we blend them to what we believe to be the best recipe so you end up with the results you expect at a price you can afford. After all, if a product is cheap and it doesnt do the job you want it to do surely you cant get more expensive than that!? We are that confident that ours will do the job you want it to do we offer a MONEY BACK GUARANTEE on all of our products, if you are not happy with the results simply send it us back along with your receipt and we will give you your money back. Some companies go overboard on their packaging investing a lot of money to make it look nice, only for you to be disappointed with the results of the product. We have done enough to make our packaging vibrant and to stand out but again quality comes first, we use the best available trigger sprays with line and mist spray with fluorinated bottles to stop paneling (misshaping) and we know you will not be disappointed with the results of the product as thats where we would rather the money went, into making the product the very best it can be. Many of our products in the valet range are concentrated creating extreme value for money with items such as our Traffic Film Remover which you can dilute up to 50-1 so the 5L will make 250 litres of ready to use product. These products before coming to market have all been tested and used by some of the worlds best race teams to make sure they live up to ours and their demanding requirements. It comes as no surprise that they always live up to expectation. So if you are looking for winning results, when nothing less than best will do, you need to look out for Power Maxed products as theyre the ones for you. www.powermaxed.com Below are items that we currently stock, however anything on website we can obviously get hold of if required. Window Glass Cleaner 30% RTU 1ltr 9.99 RRP Traffic Film Remover (TFR) RTU 1ltr 6.99 RRP Alloy Wheel Stubborn Stain/Mark Remover (Phosphoric Acid) 8.99 RRP Frequent Use Non Acid Wheel Cleaner 1ltr 7.99 RRP Tyre Dressing & Renovator 1ltr 9.99 RRP Quick Detailer 1ltr 12.99 RRP Iron Off Fallout Remover 100ml 4.99 RRP Tar and Glue Off 100ml 3.99 RRP BRAKE CLEANER 500ml 5.99 RRP ENGINE DEGREASER 500ml 6.99 RRP 5 in One MULTI LUBE 500ml 6.99 RRP SHOCK & UNLOCK 500ml 5.99 RRP Postage and Packaging for all orders under 2kg 2.99 10% off all orders above 20 So including postage cheaper than the website! Window Glass Cleaner 30% RTU 1ltr 9.99 Loosens and breaks down filth stuck to glass and mirrors. Keep your visibility perfect by keeping it clean of bugs, grime, tree sap, and mud. Non smear formula keeps cleaning an easy process. Rapid Grime Removal Low Viscous Liquid Excellent Bug Remover Removes tree sap, oil and grease Non Smear Technology Up to 5X Stronger Than Other Brands Use on Glass and Mirrors Suitable on all Vehicles and Around the House Available in 1 Litre Trigger Spray, 2.5 & 5 Litre Containers Fantastic Smell Traffic Film Remover (TFR) RTU 1ltr 6.99 Cleans and degreases vehicle bodies, alloy wheels and chassis. Power Maxed traffic film remover provides the deepest clean possible. Effective to use on all types of vehicles including cars, vans, trucks and industrial vehicles. Ideal for Car, 4x4, Plant & Truck Cleans & Degreases Fast Action Excellent Bug Remover Available in 1 Litre (Ready to use) or 5 Litre & 25 Litre Concentrate Powerful Formula for the Toughest of Dirt Suitable for all Vehicles Safe to use on Rubber, Plastic, Alloy, Wiring and Glass Will not strip wax or sealant (completely LSP safe - Minimum dilution rate of 9:1) Alloy Wheel Stubborn Stain/Mark Remover (Phosphoric Acid) 8.99 Our Alloy Wheel Cleaner has been formulated in conjunction with some of the world's best race teams. It has been designed to give the cleaning power and the finish required by those with the highest standards. An excellent fast acting alloy wheel cleaner product for those hard to reach areas. Benefits: Effective on Carbon, Tar and Road Grime Removes Stubborn Ingrained Dirt Incredible Results Available in 1 Litre (Ready to Use) & 5 Litre Concentrate Manufactured from phosphoric acid to quickly penetrate and break down stubborn carbon deposits and general road grime from alloy wheels leaving the surface deep cleansed and bright. Frequent Use Non Acid Wheel Cleaner 1ltr 7.99 Our Alloy Wheel Cleaner has been formulated in conjunction with some of the world's best race teams. It has been designed to give the cleaning power and the finish required by those with the highest standards. Frequent use acid free alloy wheel cleaner has been specifically formulated as a milder option than traditional acid when cleaning & degreasing wheels. Works by penetrating and breaking down soil particles on the wheel surface. Oil & grease dispersal properties will accelerate the cleaning process. Formulated as a frequent use wheel cleaner product. For persistent stains try our acidic formula alloy wheel cleaner stain & mark remover. Benefits: Regular use non acidic Incredible results every time Available in 1 Litre (Ready to Use), 2.5 & 5 Litre Concentrate Tyre Dressing & Renovator 1ltr 9.99 Non solvent, non-toxic, non-flammable high shine tyre dressing for all vehicles. Manufactured as a semi gel consistency for ease of application, Power Maxed Tyre Dressing contains materials that assist and enhance the appearance of tired rubber surfaces once applied directly. Specially selected materials present in formulation eliminate Health & Safety considerations as with conventional Benefits: Enhances Tyre Appearance Great Shine Non Caustic Quick Detailer (1 Litre) 12.99 Power Maxed Quick Detailer is a gloss enhancing multi-purpose speed detailing spray. Our Quick Detailer is a totally unique formula which represents hydrophobic technology which repels waters and withstands multiple car washes giving you additional protection to your paintwork. Power Maxed Quick Detailer will safely remove light dirt, unsightly fingerprints, water spots, bird droppings and even tree sap without having to wash your car without streaks. It will also reduce bugs and debris from sticking to your surfaces, It is even safe for use on your windows! Try it! Safe on all exterior surfaces, use this product between washes and waxes and enhance your paint protection. Long lasting protection and water beading action. Also try it on your Motorcycle, Bicycle, Boat, don't forget to clean your helmet with it to! Features & Benefits of Power Maxed Quick Detailer: Ultra Quick Application & Removal Maximise & Extend the life of Waxes, Sealants & Glazes Use Everyday to remove Fingerprints, Dust & Water Spots Can be used in Cold or Hot Weather Suitable for use on all vehicles, including motorcycles, bicycles & boats Protects paintwork from harmful UV rays Easy on Easy Off Application Advanced Totally Unique Formula Iron Off Fallout Remover 100ml 4.99 POWER MAXED FALLOUT REMOVER is an advanced reactive formula that specifically targets only iron-based contamination. It is suitable to use on all exterior surfaces, including paintwork, stainless steel, aluminium, chrome, glass, plastic, anodized finishes, and even rubber. Iron Off also contains strong degreasing agents to help loosen road films, making it the ultimate power in your decontamination process. Benefits Safe For Use On All Exterior Surfaces A Must Have Decontamination Product Advanced Reactive Bleeding Formula Bottle Size: 100ml How To Use Apply liberally to the surface you are treating, wait for the reaction to turn any contamination purple. After 1-2 minutes, or once the treatment has turned dark purple, thoroughly rinse the surfaces you have treated with a strong stream of water. Do not allow to dry out. Do not use in direct sunlight. We recommend that you wear gloves whilst using this product. Tar and Glue Off (100ml) 3.99 POWER MAXED TAR & GLUE REMOVER is perfect for removing bitumen tar, rubber residues, glue, and adhesive from decals, vehicle wraps, paint protection films, and wheel weights. Its strong solvent-based formula starts to dissolve contamination on contact, virtually eliminating the need for multiple applications. Benefits Extremely Strong Tar & Glue Remover Fast Acting Formula Safe for use on Modern Paints Bottle Size: 100ml How To Use Ensure surface is clean and free from loose dirt, apply a small amount to the affected area and leave to dissolve the contamination. After roughly 60 seconds, use a clean microfibre cloth, wipe away any excess and contamination, and simply rinse off. Do not allow to dry. BRAKE CLEANER 500ml 5.99 Power Maxed Brake Cleaner improves brake performance by removing brake dust, dirt and motoring grime from braking parts. This brake cleaner can be applied without dismantling the entire braking system - huge time saver! Features & Benefits of Power Maxed Brake Cleaner: Leaves no residue Powerful spray application Eliminates dust from brake & clutch parts Restores the friction of brake & clutch lining material Also suitable for all mechanical & other parts of the car Removes oil, brake fluid, grease & other dirt from metal parts For use on brake parts: drum & disc brakes, lining material, brake pads, block pads, springs, cylinders etc. For use on clutch parts: clutch lining, pressure plate and all other clutch parts ENGINE DEGREASER 500ml 6.99 Power Maxed Engine Degreaser Aerosol is specially formulated to remove oil, grease & grime from a wide range of engines & machinery. Easy to use aerosol Removes oil, grease & grime from many engine surfaces 5 in One MULTI LUBE 500ml 6.99 A modern vehicle has so many different moving parts which rely upon hinges, bearings and other mechanical moving parts. The part after time becomes less manoeuvrable with grease and lubricants wearing out. This is why we have created a range of easy to use products to stop this from happening. The Power Maxed multi-lube is a multi-purpose lubricant with an extensive range of uses. The advanced formula cleans, lubricates and penetrates tough built up deposits. It can also displace moisture and therefore prevent rust. FEATURES & BENEFITS OF POWER MAXED 5 IN ONE LUBRICANT Cleans by getting under dirt & grease, making it easy to wipe away Protects metal with corrosion-resistant ingredients Light duty lubricant (ie Cycle Chains) Displaces moisture protecting electrical systems Non Corrosive Formula SHOCK & UNLOCK 500ml 5.99 Power Maxed Shock & Unlock Spray combines powerful penetrating fluids and freezing agents which "shock free" rusted agents and jammed connections. FEATURES & BENEFITS OF POWER MAXED SHOCK & UNLOCK Frees rusted components Dual action penetrates and cools Synthetic base oil A powerful penetrator and releasing agent Releases seized rusted bolts and locks Penetrates rust, grease, oil & carbon
They certainly do. - We were lucky enough to be invited along to Rockingham with Team Power Maxed last month. Very well run outfit!
Cool!!! I'll have: 1 x Window Glass Cleaner 30% RTU 1ltr 9.99 RRP 1 x Frequent Use Non Acid Wheel Cleaner 1ltr 7.99 RRP 1 x Tyre Dressing & Renovator 1ltr 9.99 RRP 1 x Quick Detailer 12.99 Can you PM me payment details? Thanks
The stuff you sent me turned up the next day I've only used the glass cleaner so far and it was great!!! I'd already got a bottle from the pound shop and a 'streak free' bottle from Asda which were both ****e!!!! I may has we'll have used egg white lol Yours was great, I was pleasantly supprised and very impressed so Thankyou very much
