anyone no how to make a home made push button starter kit as i'm bored and want somethin to play with i assume it's a case of turn the ignition on with the key then find which wires need to be joined to start it then just wire a switch in ? anyone got any info on colours etc ???
my ignition switch packed up so i got a starter button fitted.its some sort of button from a lift. there are two options when wiring.one so it will crank regardles of key position and other will only crank when the ignition is on Edited by: alby
Looks like S2000 one but can be used to any car as far as I am aware. Often seen on ebay. My ex had a strange but clever set up on his old car which would throw a thief as there was no ignition barrel
Yup S200. Very plasticky but will look ace when installed. It needs to be used with a relay otherwise it'll burn out fast.
